Evo X Fuel Pump
![Smile](https://www.evolutionm.net/forums/images/icons/icon7.gif)
Hi guys need some help going to get 400/400 on my FQ300 Evo X, the question is will i need a Uprated Fuel Pump? Because a few people has said no and a few has said yes.
If you're talking 400 WHP, the stock pump will probably barely be able to deliver that at 25 psi boost pressure. 400 bhp, absolutely yes - that only requires 180 L/h fuel flow or so, which the stock pump delivers all the way to 80 psi.
![EvoM Moderator](http://forums.evolutionm.net/images/titles/mod.gif)
IDK why people don't already know this AMS published this very valuable info a LONG TIME AGO!
![](http://amsteam.net/files/8/fuelpumptest2.JPG)
ASK yourself, how much power will a standard walbro 255 support? (dynojet)
550-600whp on gasoline
450-500whp on E85
Now figure based on the above data that the stock X fuel pump flows about 85% of a 255 and you get:
470-510whp on gasoline
382-425whp on E85
These are damn good numbers! I still say most people upgrade way too early and this is why.
Now figure don't even crack the seal of the tank and throw a boost-a-pump on it and you can expect an extra 20% flow. At this point you'd be at the limit of a basic walbro anyways, so mod one (a wally) then throw it in and you're good to go for some pretty serious power on a single pump w/o too fancy of a setup.
Now with the stupid adapter kits you need for the X. $150 is the cheapest one IIRC? + another $80-100 for the pump, that's $250-300 you could have spent on a set of injectors or other mods
450-500whp on E85
382-425whp on E85
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Most people pay their tuner $150/hr, have to take time off of work, and have to schedule an appointment a few weeks (or longer out). They don't want to run out of fuel on the dyno if they can help it.
Your 440 was also on race gas, which requires less fuel per hp than pump. I've heard of people running out anywhere from low 400's to high 400's depending on the dyno. Given the choice I'd rather have a little headroom if I were shooting for 400 wheel.
The Boost-A-Pump costs as much as a pump kit. Single Walbro kits are pretty easy to install. I'd probably do that rather than mess with wiring. Not sure if the above chart is with a punched pressure relief but I've seen charts showing that a 255 can flow as much as an 044 (at 75psi) once modified.
It's quite possible that the OP was talking 400 crank, which is often the case in the UK. The stock pump would be fine for that.
[GBU]Moon
Apr 13, 2014 11:48 PM
XTR Performance
Evo 'For Sale' Miscellaneous
77
Jan 14, 2013 12:24 PM
