30K Service Price?
edit: also try searching a bit more.
https://www.evolutionm.net/forums/ev...ealership.html
850 ? to do this
Change Oil
Change Trans Fuild
Change Diff Fluid
Change Transfer Case Fluid
Check Air Filter and replace if needed
Change Spark Plugs
Check brake pads
Check hoses
Check belts
just DIY or buy the fluids and take it to a local shop much cheaper than 850.
850 ? to do this
Change Oil
Change Trans Fuild
Change Diff Fluid
Change Spark Plugs
Check brake pads
Check hoses
Check belts
I would highly recommend doing it yourself over the weekend. It will save Hundreds and will get you more familiar with your car. You did buy a tuner car, and even the unfun parts like required servicing are a part of that. At least do it once to know what youre paying that much for if you choose not again
