Overheating Evo X
Old Oct 16, 2010, 02:02 PM
4G63LancerEvo's Avatar
Question Overheating Evo X
Hey guys, my evo has been overheating and i got the service engine soon light. Ran up the code with the scan tool and got this:
P1320
Ignition timing retard insufficient
Anybody know what might be wrong with the car. Any help is greatly appreciated. Thanks.
Old Oct 16, 2010, 04:26 PM
Update guys: changed out the thermostat and reseted the battery. Service engine light is not on but the car is still overheating. Tends to overheat just when it sits and the fans come on.
Old Oct 16, 2010, 05:18 PM
wickedchimp's Avatar
sounds like a blown head gasket
Old Oct 16, 2010, 05:40 PM
ivanxchvz's Avatar
Is it pushing coolant out of the overflow bottle? That could indeed be the headgasket.
Old Oct 16, 2010, 06:38 PM
iziegsx's Avatar
I sure hope not!
Old Oct 16, 2010, 07:27 PM
Its not pushing coolant coolant out of the reservoir bottle. The car only has 4215 miles. Could it be the water pump??? There seems to be no coolant leaks from anywhere.
Old Oct 16, 2010, 07:36 PM
iziegsx's Avatar
Have you taken it to the dealer?
Old Oct 16, 2010, 07:50 PM
Havent taken it to the dealer yet. Bought the car used with an aftermarket cluthc and already installed intake and intercooler piping. I would assume that they could use the intstallation of the aftermarket clutch to void the warranty.
Old Oct 16, 2010, 08:39 PM
iziegsx's Avatar
I get ya. My best advice would be to take it to a professional then. Im sure you can find a reputable shop in your area. Good luck man. Ill be looking out for updates.
Old Oct 16, 2010, 08:41 PM
My guess is the water pump. I will definately take it to the proffesionals and let them handle it. Thanks.
Old Oct 18, 2010, 02:46 AM
KJ82's Avatar
+ 20
Old Oct 18, 2010, 09:06 AM
OBP
OBP's Avatar
I have taken my car to the dealership modded and they will look at it. They will charge you for it but naturally that would happen anywhere.
But if you don't think you have a competent service dept I would just take it to a reputable shop.
Old Oct 18, 2010, 05:58 PM
DK01's Avatar
Maybe the fan wires got swtiched some how... Is the fan blowing air towards the motor or the front of the car when it is on?
Old Oct 18, 2010, 06:24 PM
DaFastOne's Avatar
has your car been reflashed? If not, take off the intake and intercooler pipes and put the stock pieces back on and see if that helps
Old Oct 18, 2010, 07:17 PM
Thanks for the info guys. Got the car back from the shop. They did a coolant pressure test and turns out it had a leak, so the anti-freeze was not getting to the motor. Im glad it wasnt anything else. Thanks again for all the help.
Quick Reply: Overheating Evo X
