How to get the best visibility out of the stock HID headlight setup?
Old Nov 9, 2010, 05:14 AM
tsitalon1's Avatar
Originally Posted by total0wnage
maybe upgrade ballasts to 55watt? im sure u will gain more distance and brightness
That is a very interesting option.
Forgive me for being a lighting newb, but how difficult is that? Does anyone make 55w ballast that are PNP, or do I have to cut and splice?
Old Nov 9, 2010, 05:25 AM
showoff3civic's Avatar
Originally Posted by tsitalon1
Yeah, I just didn't want to pay for "branding". I like a quality part like the next guy, but don't like to pay extra for something just for it's name.
I have a feeling that the 6000k bulbs output almost the same light, but look so different to your eye that it appears to not provide as much...hard to say actually.
hmmm...some stealth projectors behind the grill on top might be cool
I really need to read more about ZKWR lenses....
Its not branding thats the problem, the problem is the years of research and development. For the extra money you spend of the better bulbs that are the correct temp it could have saved your life. Not to mention who knows how long the other bulbs will last, I <3 the stockers they work great for me.
Old Nov 9, 2010, 12:12 PM
tsitalon1's Avatar
Lenses backordered until 11/15.
I have a question for you lighting experts.
What dictates the width of the light output of each projector? Is it the lens?
My guess is that it is the lens , kinda like an slr lens in that you have wide angle and standard. I'm looking for wider coverage, without sacrificing to much distance. Is there a lens that is better suited to provided a wider beam than the ZKW-R?
I also am toying with the idea of pulling the fogs and inserting mini h11 projectors in their place. I am not sure they would fit in the stock fog housing though...
Has anyone seen mini H11 projectors, do they look small enough to fit in the fog light housings?
Old Nov 9, 2010, 08:23 PM
tephra's Avatar
search for that lens on here... A few guys are running the ZKW-R lens (or a copy of)
basically it makes the light output sharper as the lens doesn't have any dimpling..
i guess that translates into more light..
but yeh - aim them higher too
Old Dec 3, 2010, 09:24 AM
Evo Tengoku's Avatar
For those that have lowered their X's, do you feel visibility has dramatically decreased? I had that problem after I lowered my IX. Even at max setting on the dial, the lights still pointed too low.
Old Dec 3, 2010, 09:57 AM
WM_EVOX's Avatar
After my car's lowered by Swift Spec-R, I had to readjust by using the adjustmnet screws to bring them up. You will need a long philip screwdriver, pretty easy to do.
Old Dec 3, 2010, 10:22 AM
tsitalon1's Avatar
Ahh... I forgot to close the loop on this thread...
Here's how I improved my lighting
https://www.evolutionm.net/forums/ev...eadlights.html
Old Dec 3, 2010, 10:51 AM
HELPr's Avatar
Update this post once you get your new lenses in!
Im going to adjust my headlights a bit higher, they do seem too low even on the 0 setting.
Old Dec 3, 2010, 10:58 AM
tsitalon1's Avatar
If your referring to me, I can't. I decided to retrofit completely different projectors into the stock housings...see my link above.
tsitalon1
28
May 4, 2015 12:42 PM
lightingyellow8
Apr 6, 2015 02:17 PM
JOLLY300
Dec 24, 2013 04:24 PM
TVirus90
Nov 16, 2013 04:21 PM
slatermvp
Dec 31, 2010 07:07 PM
Quick Reply: How to get the best visibility out of the stock HID headlight setup?
