What the He** is this?
ya i guess but i used to use 5 30 all the time bro. and yes if you put to much in or to less in that could be the problem. but if not switch to 10 30 maybe thats what it was on befor and thats why.
Registered User
Yea i guess so! Bc i started the car today and no noise! I changed the oil and randomly noise starts? Im gonna go drain some oil out and have a update in 15 min.
Registered User
Idk how in the world a lifter can go bad? Old oil everything fine 30 min later new oil. Noise comes from the back of the engine! It even sounds like the injectors bc the i did the old screw driver trick that mechanics use and no where on the engine did i hear the noise. I put the screw driver onto the injectors and i heard nothing but ticking.
Registered User
Ok so this is crazy! Here is the update i just drained the oil out to make it 100% level with the MAX mark and turns out i had fricking a whole quart extra??? How is that possible? I only put 5 quarts in? According to the computer its 5.2 quarts and i let the sucker drain long. (yes the car was level) After this the noise did go away a little. Id say it got 50% quieter! So either something got screwed up from to much oil! Or the i need to drain her and get the proper 10w 30 oil.
sounds like a super bad case of valve tick. When was the last time you had the valves adjusted if ever?
My 08 X makes the same noise, but like someone else said, its bad on cold starts, and gets gradually quieter as the car warms up.
I think that means you are definitely due for an adjustment. How many miles are on the clock? Valve adjustment is something you are supposed to do every 30k.
I would do what everyone else has adjusted before ripping the head apart looking for malfunctioning lifters. Change to thicker oil, and adjust the valves.
rraulston
55
Apr 28, 2005 06:20 PM
