PROBLEM: Steering angle sensor
In theory we should calibrate steering sensor after each alignment. Bu in real life I do alignment on non-Mitsu service. In this case we can put our steering wheel to zero position by logger and do alignment on any service. If sometimes you will see this variable - please create new topic about it!
If you log something and lay the wire over the steering column, be sure the cable doesn't fall between column and wheel. That's the way you crash this sensor and maybe the spring.
Peter
Peter
KillaJay
Jul 24, 2020 01:15 PM
wazzelby
Mar 29, 2017 06:28 AM
MrDeltaKilo
Jul 21, 2014 09:57 AM
Silver06evo9mr
Dec 19, 2012 10:00 PM
