Oil Pressure light question
Well, sorry about that. I'm a ruddy idiot.
At a particular drop in oil pressure, if something goes wrong, (for example, your oil pump fails) you should get an oil pressure warning light on your dash. My question is - Does anyone know at what particular pressure that light is triggered to illuminate? For example, if the pressure falls to 40 psi does it trigger, or is it 60, or 25, etc. Thanks
Here's another question that is more on point. What psi pressure do people set for accusumps to open?
These are the oil pressure specs
Standard value:
At idle: 29 kPa (4.2 psi) or more
At 3,500 r/min: 294 − 686 kPa (43 − 100 psi)
So I imgaine that if your pressure falls too far below these values the light will come on
Standard value:
BlackEvoV
Lancer How Tos / Installations
Oct 6, 2015 11:21 AM
StlEvo05
24
Mar 10, 2012 08:31 AM
