Need help with Front Down Force
Like waltezee said adjustable front splitter is going to be your best bet. Don't waist you money on canards like a lot of people do. Also make sure your class will permit a splitter.
splitter is a good option. canards can benefit you if the are big enough and placed correctly. it also helps with the direction of airflow around your car. just make sure your splitter is positioned correctly and is mounted securely enough it is not going to cause flex.
like someone else mentioned, also check with your class to ensure it is allowable. also make sure you balance out your car with rear downforce so you dont cause the rear of the car to get loose or push in the corners.
I think I will also be looking into some coilovers, I currently only have springs. The coilovers will help tighten everything up.
Thanks everyone for the info.
Sluggo
Oct 30, 2016 06:55 PM
marcouxa1
Lancer Aftermarket Forced Induction Tech
11
Aug 5, 2016 12:47 PM
EvlEvoIXSE
Aug 16, 2015 12:49 AM
06MREvo
Jul 14, 2011 06:47 AM
