fifth gear choking
I have the same thing goin on with my '10. Guess we should leave it in 4th a little longer! It usually only happens to me if Im shifting from 4th to 5th uphill and the RPM drop to 2k or under.
Edit: OP, I took a quick look at your past posts and it seems like your car is tuned. It also looks like you'd like to increase its power further. Might I suggest that you log onto the other Evo X forum and read the 2 current threads dealing with blown motors due to running at low revs in a high gear. It may help to save your engine.
That's almost idle, what do you guys expect? It's a heavy car with a 2.0L motor with no real torque until the turbo ramps up. You're running the thing in a tall gear at [gasp] close to idle. Aside from the car having zero response, allowing one to question the reason for owning such a machine, as a Fit on the street will wipe the floor with an Evo driven in this manner, you better hope your motor isn't knocking itself into oblivion. Doing it uphill, further increasing the load on the motor, while in 5th at low revs, borders on the absurd. I'm sorry; it's the truth of it. Good luck.
Well what actually happens is as the car is going to start spooling up in 4th, you naturally shift to 5th and not realizing the rpm will drop so low and as it shifts youre right at 2k going uphill at 40-45mph and yes, the engine bogs.
Downshift to 4th until back on even/downhill surface and upshift. Its just part of learning the car is all, not like Im expecting the engine to come up with magic tq to get me up the hill haha.
You're only at full boost if the throttle is wide open. Somehow, I don't think that's the case.
Yes, so what? FWIW, My IX is rarely drops below 3500rpm, and never below 3000rpm. These are small, turbocharged, high-revving engines. V8s are great if you want to rev low.
I know the car will be over 3250rpm in any gear except 5th at that speed.
My car has a similar issue... like it wont bog even if im below 3k RPM in fifth up a hill, but as soon as I take my foot off the gas, the DV will flutter a little bit, and the whole car will shudder a little... This only seems to happen in 5th though. Is this the same issue?
