What would you do with $10k to a stock evo X?
It really depends on what your goals are.... If your looking for 500whp or looking to have the cleanest ride. I would say the majority of the guys on this board are towards performance... I'm the same way. Check out this thread, it has a lot of product testing.
https://www.evolutionm.net/forums/ev...ts-thread.html
My personal recommendation is a turbo kit and support mods and rock the stock block right around 500whp on pump gas at less then 27psi.
A signature of beauty Thanks for the support!
I dont know why people always go straight to a turbo upgrade. The Stock unit is good for 380+WHP at sensible boost levels with very little lag. So it should be one of the last things you do!
I'd vinyl wrap the car with that question first...
then upgrade with the suggestions that have been found on the car via post it notes.
odds are people will tell you to remove the vinyl.
