A good DIY for Wide Band install and 3 port BC
does anyone know of a good wideband DIY for the X? preferably for an innovate, but I can probably use any
also if anyone knows of a DIY for a grimmspeed 3-port install that would be great also!
any input would be much appreciated.
thanks!
thanks!
I guess i don't understand what you need help with in particular... if you search on wideband in the X how-to section you will find at least 6 or hits... some deal with general cable routing etc......
It's not that hard, what do you need to know about the wideband install?
As for the 3 port...
https://www.evolutionm.net/forums/ev...-solenoid.html
Search is your friend!
I searched this site and wasn't able to locate a wideband install DIY. Google wasn't able to locate a good wb install either. Search can make you feel retarted sometimes. I guess what I want to know is with the innovate which wires go where. I can run everything correctly but I don't do wiring.
what's weird about the DIY's for the 3 ports is they all say different stuff and the pics aren't that great either. They are all up close and you cant tell what the hell you're looking at when the pics are up close. I think I might just make my own DIY for both (with help of course) lol to help dumb people like me.
1 Post
Each AEM UEGO sensor is individually calibrated and a resistor integral at the connector body is laser trimmed with this value. This process replaces the traditional “free air” calibration procedure when changing sensors and implements a sensor specific calibration for unparalleled accuracy.
I have the innovate LC-1/XD-16 AFR and just installed it based on the directions that they provided. They have quite a bit of information on their website on grounding, etc, and the manual has the instructions on how to do the free air calibration. The biggest issue is being careful to make sure you have good grounding points. Unfortunately I didn't take any pictures when it was installed, but if you have a specific question I will try to help.
vortico
Jun 21, 2017 11:38 PM
maxroach
Feb 11, 2014 04:12 PM
Deceit
15
Oct 15, 2003 02:02 AM
