Sponsored by:
Sponsored by: CARiD
Evo X two step
Old Jun 4, 2012 | 03:22 PM
  #91
Robevo RS's Avatar
Lol
Old Jun 4, 2012 | 03:24 PM
  #92
Evostare's Avatar
Done!!
Old Jun 4, 2012 | 03:31 PM
  #93
migs647's Avatar
EvoM Community Team
Originally Posted by Snakes709
For 2 step on the gsr you have to hold the asc button for 3 seconds. Just like in the video above once t chimes you are good to go. The rev limit will go to 5500 and you will build 5psi.
I can hit rev limiter without touching ASC. Doesn't mean the user should be dumping the clutch with ASC on (asking for a broken diff at that point).
Old Jun 4, 2012 | 03:37 PM
  #94
fostytou's Avatar
EvoM Community Team
I can tell you from looking in the ECU that, at least in the 2008 USDM, no ASC action is required. When you pass under a specified speed (10km/s) for a specified amount of time (2100ms) the 2 step is activated while the clutch is in until you reach that speed again. You can also use this to do a faux NLTS by setting the speed to 200+km/s.
As Iowa said disabling ASC may prevent the car from cutting some boost (mode 1) and I'll tell you that putting it in full disable (off off / hold) will not help you. In fact, if you are doing this on a road course and aren't a pro driver it is probably worse. Common mistake - this actually helps you by braking the inside rear tire will the AYC pushes the outside tire more. By turning it off you are making your fancy AWD system that of a USDM evo IX or lower.
I'm closing this thread since the question has been answered. Please feel free to PM me or another mod if it needs to be re-opened.
polish_pounder
Jan 4, 2011 07:02 AM
BstdEvo9
Jul 17, 2009 02:45 PM
oneslowEV0
Mar 30, 2009 03:52 PM
ibarkovic
Jul 29, 2008 11:05 AM
Evo8you2007
Aug 6, 2007 11:28 PM
Quick Reply: Evo X two step
