What is a reflash/Tune and what exactly does it do?
Sorry if this seems like a dumb question, I looked around a bit and didnt see an answer to my question:
So what exactly is a reflash tune?
Will it void my warranty?
What exactly does it do and what are the benefits hp wise?
What will it cost?
Thankyou very much for making me feel welcome so far!
Im new here and owning my first Evo for less than a month 2011 GSR.
What will it cost?
Tune:
The most common method of tuning these cars now a days is a simple reflash. Evos have a few programs available for download that have tons of logging parameters and can be used to log and tune these cars. Any evo tuner can do this for you or you can do everything yourself with a laptop/Tactix cable/programs. You can get the car street tuned or dyno tuned. Either way, a tune is the true way to unlock the potential of an Evo. It gets you the most out of your mods and allows proper adjustment for fuel/boost/etc. Bottom line, GET A TUNE!!!
- I only mentioned a reflash because it is the most sensible option for someone new to modding
- Search the forums for tuners in your area or those that offer mail in flashes.
- Increases power as well as gas mileage.
- A TUNE IS THE MOST WORTH WHILE MOD FOR THIS CAR - WHETHER YOU INTEND TO MOD IT OR NOT!!!
Ok but what exactly does a reflash do to the engine or computer?
Approximately what will it cost ?
And will it void my factory warranty?
Last edited by formerRX8owner; Jul 24, 2011 at 05:03 PM. Reason: being more specific in my dumb questions
Cost is generally a couple hundred $. Timing advance, air-fuel ratio, boost, and MIVEC settings are the main things changed during a tune. It won't automatically void your warranty, however dealers may blame engine troubles on the tune if they find out it's on a non-OEM tune.
Wow, that's quite a list of cars owned. Not counting those of my spouse, I've own seven vehicles in my lifetime and I'm 65.
49 Chevy
55 Chevy
67 VW Bug
70 Ford Maverick
78 Pontiac Trans AM
92 Plymouth Laser
2003 Evo
49 Chevy
55 Chevy
67 VW Bug
70 Ford Maverick
78 Pontiac Trans AM
92 Plymouth Laser
2003 Evo
A tune is changing the settings on the car's computer. This is saved as a "map," or new settings file. It will cost $300-$500 to get a professional to tune your car and it's worth every penny. I got my 08 GSR tuned and it gained +53 whp with no mods lol. Some tuners have gotten ridiculous gains -- TTP Engineering in Florida has seen 70+ hp gain with no mods after a tune. The car drives ok before, but if you want to get a boner in your car everyday, get it tuned. The car will absolutely throw you back in your seat and rock your world in 0-100 afterwards. It's the best money spent.
Gas mileage wise, there is little to no change. I got 240 miles per tank before, and 240 after.
It will void your warranty at a lot of dealerships even though by law it's not supposed to. Who cares about the warranty though -- they will try to dick you out of a repair no matter what, just because it's an Evo.
+1 Ditto
It can not void unrelated parts like brakes, suspension, stereo, window motors, etc.
- If horsepower gains from a tune are so cheap and easy, why does Mitsubishi itself not do it?
- How many of the people who will sell you a tune will warranty your engine against damage?
- Of the people on this forum who have reported blowing up their engines, what percent were tuned?
If you do more research, you will find that the questions above are all related.
(Note: the FQ cars sold in the UK are not actually products of Mitsubishi. They are tuned and warrantied by the UK distributor for Mitsubishi.)
my advice would be get used to your evo for a few months.
give it time to settle in and anything that "might" break, break...
then start modding...
the biggest advice I can offer is find a tuner that is good - there are lots of bad tuners out there...
some intentionally bad (read slack), some unintentionally bad (read not knowledgeable)...
to get the most bang for buck, you wanna put a HiFlow Cat in and maybe a catback and then get a tune... You should be putting out a just under 300whp on a low reading dyno...
your warranty will disappear, however that should only affect drivetrain - It really depends on the dealership, it sounds like you are a bit older so you might get away with it.
I reckon out of the thousands of tunes on "stock" evo's out there I have probably heard of less than a handful with problems...
cost wise, anything less than $250 is a bit suspicious... Anything over 1k is a rip... Road Tuning is cheaper than Dyno Tuning... And unless you have the right equipment isn't going to get you the best result...
Lastly - A tune will transform the car, not tuning an Evo should be considered a crime...
