Gears Grinding a little
1 Post
Okay I have a 2010 EVO X GSR with about 7200 miles on it
When I shift into 3rd gear sometimes at lower RPM it grinds.
I'm pushing down on the clutch all the way and it still does this
Does anyone know why? 3rd to 4th and 4th to 5th never do this but sometimes 1st to 2nd and 2nd to 3rd do
This is my 1st EVO and I am a novice Manual Transmission driver
normal, here's a good thread to look at
https://www.evolutionm.net/forums/ev...on-thread.html
switching to the redline cocktail that kracka uses improved the feel for me.
1 Post
Speed shifting bad, I'm guessing your synchs are trashed. But I'm not there so it's a total guess. Completely flush your tranny fluid drive for 30 min then flush again. If the problem still persists I would go to the dealership and see if they won't cover you under warranty.
Syncro's are brass, bronze, or soft steel that are used in between gears to help them mesh up. It's a bit more complicated but that the basics
His synchros are fine, this is normal.
2 quarts of Redline MTL + 1 quart of Redline MT-90 fluid
Plus whatever brand of transmission/shfiter bushings you prefer; I have WORKS, but Torque Solution, AMS, TWM, etc. all make them too. I also have a WORKS short-shifter. All together it makes for a wonderful package, my X is the 2nd best shifting car I've owned after my S2000.
1 Post
Any idea of where I can buy this or is it only sold online? And thanks for your help
you cn get it here
http://www.maperformance.com/redline...ktailevox.html
1 Post
you cn get it here
0 being a 90 year old granny could do it and 10 being very difficult
*Replacing my manual transmisson fluid with new fluid
Called my local Mitsubishi dealer and they want to charge me $75.00 for the labor >__>
http://www.redlineoil.com/dealers.as...=retailer&id=4
it will give you dealers in your area. if none by you, then will have to mail order. (i'd rather pick up fluids, rather than have them mailed, just incase so nothing gets broken) But you got to do what you have to in order to get what you need....
its easy, hardest part is remove all the damn push clips on the under tray. on your scale prolly around a 2. takes a little while to pump all the fluid in. but thats it.
heres a link to the service manual.
https://www.evolutionm.net/forums/mi...ml#post6750417
and heres a link to a how to
https://www.evolutionm.net/forums/ev...ed-manual.html
