Hesitation at 3200rpm on New Stock GSR
I notice it significantly more with my CBE on that I did before. I bet a tune would fix it, if that's not the route you want take it to the dealer they'll reflash the ECU. I'm taking mine to the dealer this week
Are you refering too slow acceleration near 3500 rpm that builds 1-5 psi boost and then as you let off slightly there is a quick hesitation?
I have the same hesitation, right around 3k rpm. It's not turbo lag, I get it while just cruising. I can hear the BPV fluttering when it happens sometimes, usually when I'm in 4th or 5th gear.
Not bad gas. It's been consistent since I bought the car. Minor issue, and I'm hoping a tune will fix it. My old STi had a similar issue around 3k rpm as well, and a few open source guys from RomRaider (Airboy) figured out that we could adjust engine load compensation using plots from LTFT logging. I hear that the actual problem was mechanical, but we fixed the symptoms with tuning. Don't know if this is related, probably not.
blaze_125
Lancer Troubleshooting
Dec 2, 2011 09:52 AM
GetterDragun
Feb 22, 2011 08:24 PM
Mojito
14
Sep 4, 2009 04:03 AM
