Smartycam for Evo X
Smartycam for Evo X
Hello guys,
I'm considering to buy smartycam with ecu bridge to use on the track with my Evo x. I'm not really sure if it's 100% compatible with the car. I've been searching for opinion about this product on Evo but got nothing so far.
Have anyone been using smartycam on Evo X ? how is the experience ? What do I need to get beside the camcorder?
thx
thx
I think evoscan had this feature in beta right now. So you could use a gopro or any other camera and log with evoscan. You could always manually line up the log to the video also.
I worked for AiM for two years and specifically worked on SmatyCam development. I am running an EVO4 data logger and a MyChron 3 display. The only thing that does not read correctly is the boost. Everything else works as far as I know. I would suggest getting the Solo DL so you will have data and video as well as a lap timer with display. Otherwise get the ecu bridge. But make sure you get the CAN bridge and not the OBD/CAN bridge with the OBD connector. Even though CAN should be on pins 6 and 14 AiM is not able to read it from there. You can tap into the diff controller under the dash. Thats where I am tapped in.
I also have the LCU-1 lambda controller and a 3 bar external MAP sensor. I log all this data as well as display it on the display.
Thanks jordantii
very good info. I don't want to go crazy on data logging, but have some solution on video. and I definitely don't want to have laptop in the car on the track :-)
I probably will get smartycam with CAN bridge. will let you know how that go. I plan to get the AIM bridge for my other car if all works out well.
Thanks jordantii
mrfred
82
Jan 3, 2020 04:18 PM
