Who replaced there clutch and how long did it take ?
Old Oct 13, 2015, 09:04 AM
Tsane's Avatar
My oem clutch lasted me 101,000 miles. I changed it a few weeks ago. Took it too a shop and it was around an 8 hour job.
Old Oct 13, 2015, 09:37 AM
rafaron's Avatar
I had COBB of Plano replace my clutch kit and they usually need a day and a half to replace and do alignments after that.
Old Oct 13, 2015, 12:21 PM
CaptainCrunch's Avatar
This gives me hope. I bought an Evo a few months ago and started reading the forums and saw so many clutch replacements early on, thats been my only real fear. I don't ever launch.
Old Oct 13, 2015, 03:48 PM
Opalivian's Avatar
Took a few day to ship to store. Store installed it in one day for me. I purchased the Exedy Stage 1 Clutch. The clutch is a lot more heavier than the OEM. You MUST get an aftermarket Clutch Master Cylinder (CMC) as soon as you change your clutch, or the plastic one will break and your clutch will stay on the floormat. I bought the AMS CMC and it has been working perfectly.
Old Oct 14, 2015, 06:20 AM
jakgal04's Avatar
Throwout bearing turned to dust at 30k, put a new clutch in since it was apart but the stock clutch still looked relatively new.
Old Oct 14, 2015, 07:12 AM
GaBe511's Avatar
I'm at almost 60k on stock, oh and btw, OEM is an Exedy clutch.
Old Oct 15, 2015, 07:47 AM
MelX's Avatar
I have 165,000kms and my clutch was replaced before I owned it at some point (bought with 160k). Supposedly a stage 2 but it started slipping last week. I'm also looking into what kind of clutch to get... I was leaning towards the Exedy stage 1 HD but it seems like they don't last for very long based on what I've read. I would've gotten a stage 2 Exedy but they're all 3 pucks. I'm looking at a full face. I'm leaning towards the Spec 2 or Spec 2+ now. Anyone have experience with the Spec clutches?
Old Oct 19, 2015, 11:27 PM
desant78's Avatar
I just did a clutch replacement myself, and I wouldn't describe as "hard." I'd describe it as "having a HUGE learning curve"
It's a tight engine bay, so most of my time was spent "how do I reach that bolt? top or bottom? 1 or 3 extensions?" This is what took so much of my time. It went together in about 2 days working like 3-4 hrs at a time.
That being said, the hardest thing for me was bleeding the transfer case, which has to be done when the t case is removed. I followed the MAP write up, which was really good, except it never mentioned how to bleed the clutch.
The method I used to bleed the clutch, after a lot of reading, was to jack the car up, and have a friend spin the driver side wheel. While this happens, bleed the car.
Best of luck!
Old Oct 20, 2015, 04:55 AM
Johnr352's Avatar
Trackside... 5 hours. I didn't touch it but the guys knew what they were doing. A little tougher on jack stands.
Old Oct 21, 2015, 03:27 PM
whatever210's Avatar
Originally Posted by cweav
I am currently on my 4th clutch. Stock went at 20k, exedy stage 1 went at 25k, exedy twin went at 41K and I am currently on another exedy twin. Needless to say I have a lot of practice, I can have mine done in approx. 6.5 hours with no breaks. I recommend taking out the pill. It made the world of difference. As for brand ACT or Exedy are both good IMO.
Originally Posted by LastX
Okay, so it sounds like Exedy clutches suck, so what other brands are recommended? Sorry, but an 10 hour shop job every 5k-15k doesn't sound normal unless you track your car or are otherwise hard on it.
Kevin
Not at all. A lot of ppl including myself at one point think that have a twin disk last longer. When actually that's false. Those twin disk are race clutches and the disk aren't as thick. They do hold more tq but it's not a clutch that's meant to daily. Most twin disk guys only get 15-20k on them if your daily driving it. I know comp clutch stage 2 will last for a long time and it's a round disk. People over do clutches like crazy.
Originally Posted by shekaar
Hahaha. Exedy makes a good clutch. Someone just doesn't know how to drive a stick.
He may have had to much tq for that stage one. Prob should have been stage 2.
Old Oct 23, 2015, 11:30 AM
dmotors88's Avatar
The shop took a day and a half.
I bought an ACT Clutch (ME3-HDSS) and ACT Flywheel (600550).
Grabs great I love it.
Old Oct 23, 2015, 07:03 PM
Lightsaber's Avatar
Kevin
Exedy clutches are great. They are reliable and made to the highest quality control standards.
Since the Evo clutch is already so heavy, for daily driving and occasional track, OS Giken is another brand to think about. They are renowned for making powerful, light-on-the-pedal clutches.
Old Oct 24, 2015, 05:28 PM
LastX's Avatar
Okay, good to know, I should be good then. My first car 35 years ago was a standard, and have many since. I just was worried having heard so much in here about clutches, and also the quirky shifting. Mine has 7k on it, and it's is crunchy between 2-3 and sometimes hard to get into reverse, and on occasion into first. Just assumed this might be a clutch thing. But I certainly know how to drive a stick.
Regards,
Kevin
AJ18
19
Apr 21, 2017 08:15 AM
lbwilliams44
Nov 28, 2016 12:31 PM
BoostNY
Apr 28, 2016 08:01 AM
Jhurley_EvoVIII
14
Dec 8, 2015 12:47 PM
evosnstuff
Nov 8, 2015 12:05 PM
Quick Reply: Who replaced there clutch and how long did it take ?
