Boost Pill direction
OK so I removed the boost pill for the Cobb AP stage 2 and I am going back to stage one. Which direction does the larger opening of the boost pill face? Away or towards the engine? Any help would be greatly appreciated.
Edit:
Found it
It should be a little less than an inch from the T- connector.
Make sure when reinstalling the boost pill that the bigger, open end faces upwards towards the outlet pipe, the smaller end facing downwards. Car will over boost if facing the wrong direction.
Edit:
Found it
Optiblue
26
Feb 20, 2014 01:05 AM
