ticking idle noise
Old Mar 5, 2012, 01:08 PM
TEMPELIS's Avatar
ticking idle noise
is this a normal sound?
there is a ticking sound coming from around the engine area. i posted a video with the noise. you can hardly hear it in the video but in person its much louder and can be heard with the hood closed aswell. my car is stock, i only changed the fuel pump relay to blue a month ago.
Any help or feedback..
http://youtu.be/yIgt8klK8K8
Old Mar 5, 2012, 01:21 PM
EvoX4life's Avatar
If I had to take a guess I would say the its the fuel injectors ticking. My car and other ars on evom have experienced the problem and that is what all the cases I have seen. Also I took it to the dealer and he said it was just the injectors. They said it was normal for evo's. Thats my 2 cents
Old Mar 5, 2012, 01:29 PM
Sev
Sev's Avatar
Mine does it too. I think it's normal.
Old Mar 5, 2012, 01:43 PM
J Dog's Avatar
Sounds just like my X and other peoples X's that I've come across.
Old Mar 5, 2012, 04:17 PM
TEMPELIS's Avatar
are you guys sure its not anything? the other night i was stopped at a red light and my engine was dropping to 400 rpms and almost dying and my headlights were dimming as the rpms went down, almost synchronized , then they would go up again to 800-1000
Old Mar 5, 2012, 04:28 PM
1012Xmr's Avatar
Mine sounds the same how many miles on yours?
Old Mar 5, 2012, 04:35 PM
TEMPELIS's Avatar
5800
Old Mar 5, 2012, 04:42 PM
EvoX4life's Avatar
My idle bounces usually between 800-1000 to sometimes dropping down really low where it sounds like my car is basically shut off for a very quick sec(If my idle is lower then normal then I just move the steering wheel a half of an inch either way and it will pick up). Didn't happen until I had tp/catback/cai. But X's idle is pretty bouncy so its normal. Now as far as it bouncing and lights dimming that never happened to me so idk what can cause that
Old Mar 5, 2012, 04:55 PM
jdmEviL8's Avatar
have u checked if your vacuum line by your fuel rail has popped off?
Old Mar 5, 2012, 05:00 PM
TEMPELIS's Avatar
sorry but where exactly is that?
Old Mar 5, 2012, 05:01 PM
jdmEviL8's Avatar
there is a little vacuum hose located on the passenger side of your fuel rail that connects to the intake manifold.
you will need to pop off your plastic engine cover to view it, but from the factory the line is not secured and usually pops off causing rough idles
Old Mar 5, 2012, 05:49 PM
airgazem's Avatar
Yep sounds just like mine does. Also the ticking comes and goes.
Old Mar 5, 2012, 06:02 PM
rebdull's Avatar
same same
Old Mar 6, 2012, 11:40 AM
Darksun280's Avatar
min tickets loud as **** once it's near time for an oil change
Old Mar 6, 2012, 12:11 PM
SudzRA's Avatar
My X does the same thing, and my RA did it too. It's normal.
Quick Reply: ticking idle noise
