Fast Key Change?
Fast Key Change?
So I have 2011 GSR but I was used to the 2008's and 2010's. If you haven't experienced both then you probably wouldn't have noticed the difference, but in the 2011+ models it seems that the fast key option will let you open the doors only by pressing the button. But in the earlier models it was some kind of bioelectric handle, so when you simply went to grab the door it would unlock so it looked seamless. Now, I want to go back to that style instead of pressing this button, has anyone done it or does this bother just me?
to the OP you are correct, on my 2010 all I simply have to do is be within range and the door will open, whats nice is you can change the setting of some of the elements of the fast key for example if you have a Mitsubishi Navigation System, you can change the settings so that all the doors unlock: Go to SET > Equipment > Power Door Locks > Unlock Operation. If you don't have a Navigation System, you can still change the settings by using the buttons on your FAST-key fob:
■Step 1: Press and hold Lock #1 button.
■Step 2: While holding down the Lock #1 button, wait four seconds and then Press and hold Unlock #2 button (do not allow more than ten seconds to pass). Step 3: Keep holding down both buttons and then release Lock #1 button first.
■Step 4: Release Unlock #2 button second.
Repeat the above procedure to return the settings back to the default.
-Disregard- i'm an idiot, I don't have the fast key option, just the regular keyless fob, my bad...
tried it twice on my GSR (no Navi) twice no luck... Tried it out of range of the car and within range of the car...what does the car need to be doing (ie. does it need to be unlocked, locked door, door open, anything else i could be missing)
Yes, I had an '08 and now have a '12 and it only unlocks by pushing that button. Although I had some issues in the winter with gloves on where the sensor wouldn't sense my hand which was a pain, so I guess the button is better in that regard.
Maybe it's just the lazy american in me but not having to push that button was sooo much better lol...
Still better than reaching for the keyfob though.
Gh3ttoRoM3o
Aug 16, 2018 09:28 AM
pinegreen
15
Jul 25, 2014 04:28 PM
evo_soul
Toronto Lancer Club
27
Sep 5, 2012 07:26 PM
Mr.IX
Nov 22, 2010 09:13 AM
