hey what is that oil line that is right under the oil pump? I just broke it
Found a little leak coming from the banjo bolt right under the oil pump, near the drain plug. I tightened it but didn't realize the entire line was turning when I torqued it. Started the engine up and oil sprayed everywhere
is that the turbo feed line? what is that? I need one overnighted
