coolant?!?
If it is VERY low you may have a problem. Adding a bit at 30,000 miles is nothing. I'm surprised you haven't needed some before that. It's an easy thing to swap and so you might consider a sooner interval than 30k. Keeping it fresh will keep it cool, clean and effective.
If just topping off, this is normal... remember coolant is 50% water and 50% coolant. Some of the water mixture will exaporate overtime. Normally from winter to summer or summer to winter some coolant is lost due to temperature changes.
Interval is a differnet story. 30k is low in my books (unless its not a long life coolant/antifreeze mix). Long life coolants are normally good for 3-4 years or 50, 000 miles. Id personally check the PH level of the coolant first and go from their
From the time the coolant is introduced into any type of engine it starts a gradual degradation process into corrosive acids. This degradation is a function of time, temperature and the types of metals used in the engine and components construction. Once the coolant turns acidic all engine metals start to dissolve. The results are leaking water pumps, heater cores and radiators.
Just a piece of mind to remember
WTB[MidWest]: Looking for Aftermarket coolant overflow tank
TxFAkuma
Sep 14, 2016 02:40 PM
EvoCop
Evo X How Tos / Installations
14
Jul 11, 2015 11:09 AM
Evolessfornow
Feb 10, 2009 05:44 PM
