Greasy stripes on side if car
Im seeing some grease stripes down the side if my car. At least I think it's grease. Is it common for crap to go through the fender vents? There is grease like material all the way back to the quarter panel. Not huge globs, just an inch or two lines of it. I'm thinking about removing the vents. Will this really dirty the side of the car or does not much dirt get through that area?
Thanks
Thanks
i don't understand what the hostility is about, it sounds like he has a legitimate problem on his hands.. i for one have never seen oil coming out fender vents and have no idea how the heck that would even be possible.
Exactly. If you want to condition your tires to keep them looking nice you should spray them with APC and brush them off before rinsing. To finish, just wipe a rubber and vinyl dressing on it with a soft sponge. It won't look greasy, and definitely won't sling all over the car.
Could be corrosion protection aka. Wax. It is on the insides of panels that don't receive as much paint prep as accessible surfaces. This is a very common problem with German cars. You wouldn't typically see it coming from a panel that has an accessible backside. Usually you will see it leaking in hot weather from the bottom of the doors or trunk. But I would bet that is what you have. Try cleaning it with 3M grease and wax remover if it doesn't come off with soap and water. But remember to reapply wax if you use the remover. It will also clean the wax off your car. Hope this helps...
But I did get that PM you sent me about your mom washing my car for me in her g-string, I think I'll take you up on that offer. Have her wear a white t shirt as well.
I don't get it. I just wanted to make sure something wasn't coming out of the front of the car. Seemed like a simple question.
^that's really the only thing it could be if it isn't something for detailing the car/tires. it would have to be a pretty serious loss of grease and would have to be flinging around in the wheel well for quite a while to get as far as the vents. plus it would be gray/silver in color.
