How do you get this bolt in?!
Old Jun 2, 2012, 11:54 AM
BaumBizzle's Avatar
Using the stock bolts from the O2 housing how do I get this in? I bought the DP from another member so if I would've bought new do they come w/ different hardware? It's a MAP O2 dump DP….thanks
Old Jun 2, 2012, 12:07 PM
SD_Lurker's Avatar
Take all the bolts out and pull the downpipe away from the turbo..then put that bolt in first before anything is even tighten down.. Tighten that one first.. You picking up what I"m putting down?
Old Jun 2, 2012, 12:09 PM
evotap's Avatar
i installed the same dp a little while ago, i just put them all in loosely before i tightened them. no problems here doing it that way
Old Jun 2, 2012, 12:11 PM
evosam726's Avatar
same thing i was gonna say
Old Jun 2, 2012, 12:14 PM
TJs98GT's Avatar
yupp....what they said!
the alternative would be putting a stud in there and then just having to throw a nut over it.
Old Jun 2, 2012, 12:35 PM
SPANKED's Avatar
Right, that location is a stud on the OEM hotside/02 housing.
Old Jun 2, 2012, 12:47 PM
foxbear2277's Avatar
lol start taking it apart
Old Jun 2, 2012, 01:10 PM
BaumBizzle's Avatar
Fml...welp guess I know what in doing later hahha thanks guys
Old Jun 2, 2012, 01:50 PM
black E's Avatar
The Map DP needs 2 studs and 1 longer bolt and nut for install
Old Jun 2, 2012, 01:55 PM
BaumBizzle's Avatar
Is that what it would come with had I bought it new from map? Their install directions didn't say anything about that....
Old Jun 2, 2012, 02:18 PM
sideway180sx's Avatar
you can try a shorter bolt
Old Jun 2, 2012, 02:27 PM
brenner's Avatar
shave it down a touch...
a wise man once told me - "spit on it, it will always go in"
Old Jun 2, 2012, 06:56 PM
planb x's Avatar
put the bolt thru the other side and put a nut on it. thats what i did with my map downpipe
Old Jun 2, 2012, 08:13 PM
black E's Avatar
Yes
Old Jun 2, 2012, 08:22 PM
BaumBizzle's Avatar
Where do the two studs and longer bolt go?
Quick Reply: How do you get this bolt in?!
