Does the ETS intake require a tune
Hey guys I was looking at purchasing the ETS intake and was wondering if it required tuning the car. I'm going to tune the car eventually but for now I didn't want to void my warranty.
Any mod you do to the car could give you warranty trouble. As far as tuning goes, most intakes require a tune to maximize it and run correctly. But I doubt you'd have any trouble running an intake untuned for a while. I ran some basic bolt ons for a while without a tune. Just keep an eye on your AFR if you have a wide band.
According to mike from ets the intake is made to run on the car without a tune.
Warranty work as long as the intake isn't part of the problem you can't have you warranty voided.
So your cv joints break for example, the intake can't cause that.
I've been running un-tuned for a couple months with the ETS intake. I'm doing my best to take it easy until I can get down to Boostin' at the end of the month. But, since the install, no issues. I also have UICP and LICP with a 3" ets FMIC and ETS cat-back. Can't wait to feel the difference of a good tune.
Stock tune is generally rich so you wont hurt anything by adding a little more air. Not in the short-term anyway
Evoxkidd (Apr 17, 2021)
We designed the intake to use the factory maf housing. This allows the scaling to stay the same and not require a tune. Our intake does lean out the car a little, but from the factory this car runs pig rich. If the car has been tuned on stock airbox, I do not suggest bolting on our intake without a retune.
Thanks!
Thanks!
Thanks for the info, I was planning on buy the intake very soon, and then in a couple of months, buy a cbe. I don't want to get the car tuned because this is my daily, and I do plan on keeping it for a long time, so I don't want to void my warranty out. According to the maintenance guys at Mitsubishi that I talk to, bolt ons like intake, and cbe will not void out the warranty
fortunately the intake is one of the more easier mods to install and uninstall. so you wont have to worry too much about warranty. but like the others have said, if you want to maximize performance out of it, you should get it tuned, but you can wait till you get other mods to go with it.
rather then going one mod at a time i went with a small bundle if you will. Intake, DP, TP + tune.
Do you still have the rough idle after the tune? I had the same problem with mine and im wondering if a tube will fix the idle issue.
A million people will probably say this, but try and get a tune by a reputable tuner. It made my car SO much better in several ways. Faster, obviously. Not massive numbers (321whp and 311 tq), but the car is way faster because there is a lot more power throughout the rev range. I was SO dissappointed with my evo when I bought it initially because the power was all at 5k and I really didn't like the drop-off. The tune is the best money I have ever put into this car, or any car i've had, really.
Mine is tuned by Wasatch Turbo Factory here in Utah, so good!
Intake and CBE, car should be tuned. It will be on the lean side, and you'll notice that it's kind of stumbly, especially on tip in. A good 300whp tune from a good tuner will be just as reliable as stock.
badwheel
Jul 15, 2017 04:04 AM
tscompusa
Evo X Dyno Results
Apr 30, 2017 04:10 AM
ShiftyPenguin
Mar 28, 2017 12:12 PM
Superchargedk20
Sep 18, 2016 07:56 AM
