Engine Oil Capacity
Yeah Kracka has a point too, depending on how you drain the car (front end up on jack stands, or whole car on a 4post lift) it doesn't hurt to do a fill on any car about -.25 to -.5 qts, and then follow the process of idle and then top off.
The shop I worked at we used to get a really good at know of specific models that would be off from what the manual said, but we always did the idle and recheck.
Also, any time you use a different brand of filter, is when you want to be sure to do a recheck. The filter capacity might be listed as the same, but generally can have some variance.
We run a Moroso racing wingate oil pan and Accumulator system with 7.5 qts of oil. The Accumulator is under pressure to handle oil imbalances but I suspect it doesn't get unloaded often.
Don't overfill though.
chaotichoax
Jun 8, 2020 06:10 AM
Abacus
Mar 21, 2017 07:10 AM
ImsoevoX
Sep 12, 2011 04:41 PM
