I need an Air Intake in terms of performance + more power .. (Any recommendation)
Old Aug 23, 2012, 10:50 AM
mb.8008's Avatar
guyz ,,
i'm kind of unhappy of my K&N Typhoon Intake
as u can the link below:
https://www.evolutionm.net/forums/ev...e-you-buy.html
and i wanna get AMS Short Ram, as i was google'ing saw people talks about the AMS Short Ram & AEM Cold Air Intake System,,
BUT i don't mind if u recommend any other Air Intake
i need more performance + more power + more air flow
plz share ur info & knowledge
Old Aug 23, 2012, 10:56 AM
Kracka's Avatar
All intakes are going to make about the same power. The AMS intake does require immediate tuning due to replacing the stock MAF housing. I personally have a Cobb inlet tube with an AFE Stage 2 DryflowS intake @ 416whp.
Old Aug 26, 2012, 12:02 AM
melachu's Avatar
I have the injen intake. I wanted it because it has a heat shield and is the farthest away from the engine and is a short ram. I like the aem intake also but I just couldn't hear the stock bov and spool.
Old Aug 26, 2012, 12:05 AM
Leopard's Avatar
I'm probably going with a CBRD CAI.
Old Aug 26, 2012, 12:16 AM
cdmassee's Avatar
ETS makes a good intake! It would be sufficient for your power needs! And it relocates the BOV.
http://www.maperformance.com/ets-col...s-evoxint.html
But, would most likely need a tune with it.
Old Aug 26, 2012, 04:12 AM
MisterHappy's Avatar
ETS all the way, but you don't need a tune with it. It doesn't replace the stock MAF housing, and its made to run safely with the stock tune.
Old Aug 26, 2012, 09:58 AM
The Unknown's Avatar
ETS! I couldn't be happier.
Old Aug 26, 2012, 10:23 AM
johnnnyjeans's Avatar
ets
Old Aug 26, 2012, 10:59 AM
Mischief1281's Avatar
I just ordered an ETS intake after a couple weeks of researching. I cant wait for it to get here and installed. Everything I researched on it said great quality/performace gains, excellent customer service all for a resonable price.
Old Aug 31, 2012, 02:59 AM
mb.8008's Avatar
thanx every1
Old Aug 31, 2012, 09:11 AM
AGinHD's Avatar
Im considering between the K&N and the ETS intake for my 2012 gsr. Are they both short rams? and will I be able to hear the stock BOV and turbo spool as well? lol
Old Aug 31, 2012, 09:47 AM
m0nkie's Avatar
soo ETS is a plug and play intake? I'm trying to put on as many parts as I can without a tune.. the rest I'll install at the shop.
Old Aug 31, 2012, 11:08 AM
TheBlade's Avatar
You will on both. Also, as the OP pointed out the install of the K&N works on the GSR, but not the MR, so you should be fine if you decide to go that route
TheBlade's Avatar
Totally is. If you have any questions give them a call Michael was awesome in my dealings with him.
Old Aug 31, 2012, 04:17 PM
Panda_stunter's Avatar
With any intake, u can run without a tune....but u wouldn't get the full potential if u don't get a tune.
Aem intake gives u extra 20hp without tune, but with a tune, u get a total of about 40hp.
ETS, AMS, Cobb r all reputable names so going with them isn't a bad idea. I only went with aem because it is housed. MAF tube will be changed as well with aem but I know I ran the car without a tune for a few days then I got the Cobb accessport.
Quick Reply: I need an Air Intake in terms of performance + more power .. (Any recommendation)
