List of pros and cons!
I know there was just a post recently where someone asked people to list which year they recommend and why, I am more looking for a "list" of pros/cons of years, what they added/took away each year for the X's, or if this list already exists can someone give me the link? I have look everywhere and cant find anything.
But to answer the OP,
2008- had a horribly rich stock tune. Red taillights, and red LCD screen on the dash. It also had flat grey plastic on the A/C knobs. The diff pins were made with a softer metal than Mitsu should have used and some have had failures. The 2008s also came with aluminum valve covers. Only GSR and MR models available.
2009 - There was no USDM model of the X for this year. Although rumor has it that they had started development on the XI
2010- Mitsu upgraded the taillights to the Ralliart/black tails on the 2010+ models. Side skirts were changed to prevent the rock chips that occurred on the 08s without the Aero kit. They also changed the LCD screen to color and added chrome to the A/C controls. The Touring model became available for the MR- Full Leather, while the GSR "SE" model was released for it's one year run. The valve cover was changed from the aluminum one to a plastic valve cover. The leather on the steering wheel was changed. The stock tune was improved quite a bit from the 2008
2011- The timing chain began to be upgraded to the new one, and the diff pin issue was resolved. "FUSE" was introduced. The 2011+ spoiler was slightly altered, and the "high" spoiler was made standard. Since the spoiler was now standard, the SSS package was changed to the SS package and the SL package (sunroof and leather) was introduced to the GSR. One of the tubes on the coolant overflow bottle stopped coming on the car. The exhaust was redesigned to make it a little louder and to make more power. Mitsu got rid of the sensors on the door handles that unlock the car when using the Fast Key. Evos 2011+ with fast key, you have to use the button on the door. Again, the tune was improved.
2012- Tune was improved again, although there are some instances where the 2012's aren't making quite the power of previous models, although it is mostly rumors now since the 2012s have not been out as long. The "Piano Black" dash panels from the MRs were made standard on the GSRs. The Aero kit from Mitsu was changed- The side skirts no longer come with the Aero kit unless you order them separately. On the Evos without the SS package(HIDs and projectors), the DRLs were disabled. The door panels were made more "plush".
A simple search does you wonders
Can anybody shed light on what the aero package is? im wondering if i have it or not.
