Playing with MUTIII
Playing with MUTIII
Hi! I’d like to have some advice from some MUTIII user.
Last Friday I was in my trusted dealership and I was allowed to play a little with their MUT.
I’d like to check for the S-AWC pump update (cold climate) and for SST software upgrade (I don’t think that my 09MR has the teach-in software for clutches wear).
1) Is there a common database where every MUTIII can see the updates?
2) I’ve seen that I can access to SST – AWC menu from different windows and I don’t know if I’ve done the check in the right way (no update for me) so... can someone kindly tell me from the MUTIII main menu how to check the availability of these two update?
Thanks a lot!
Thanks a lot!
the latest and greatest from mitsu uploads to the mut every night. the mut then has all updates in the laptop. when you hook it up to your vehicle, it checks the rom id. if a newer rom id is available for your vehicle, it will ask you if you would like to update, and give you a brief explination of what the update is a correction for
EyeDreamt
46
Mar 19, 2023 01:41 PM
mr2turbo18
Apr 21, 2014 05:35 PM
mb.8008
Sep 24, 2012 09:49 PM
