Noo! Hit a curb with my baby;(
Hate to say this happend but im just very currious to know how an awd plays a part in a accident so first snow fall i was unable to make the stop in time i was turning right when my vehical carryed over a single lain and my left front and rear driver side rims made contact with curb at about (15-10 km )at about the same time no visual bent rims not a decnt contact mark ( no worse then a bad curb rash)and now my left side of my vehical seams unbalanced no really steering aligmint problem just very noticacble egg shape feeling(driver side when driving over 60km ) please help!! What did i do !?
Wrong tire choice for snow?
Ice?
Acceleration into the turn on slippery surface?
IMO, All single car accidents are driver error.
I would suggest to have the car inspected
Both for drivetrain damage and also wheel damage.
Not everything you can see is visual. You might have a cracked rim inside.. who knows.
If you have insurance, this would be the time to use it, as it will be a hefty expense getting a full inspection done and probable repairs.
the first thing I did after buying the Evo was find a good alignment shop and purchased a life time alignment.. I go back every 30k miles (or hit the curb/speedbump/dip) to have mine aligned and balanced..
it'll save you alot of tire and $$$.. an alignment for your situation will cost 80-120$.. lifetime is only about 200$
One of the roads near my work had what looks like the city bus sink into the asphalt from the heat and it formed a 5-6" ridge near the middle of a lane. As I was turning onto the street the ridge wiped out a rim and tire. I totally understand your frustration.
Damage:
The Fix:
Damage:
The Fix:
This has happened to me, My wheel was tucked further back towards the rear fender liner.
Tried an alignment, lower control arm, and nothing... Replaced the subframe and now it's perfect.
Subframe was bent.
Get it checked out asap!
Subframe was bent.
To fix it:
wheels balanced and re-alignment(must do to prevent further mechanical failure)
To prevent this happens again:
Drive safe
Have a good car doesn't mean you should drive fast
Drive safe
I would get this checked out i did this once and broke and axel. You dont want to no the price for that lol. I would have a shop check everything out make sure you are good to go and peace of mind. You dont want to be drive on the highway and find out there was something wrong other then what you say driving at thoes speeds.
