Transmission oil change
Im nearing 30k miles and planning to do trans oil change. . Any recommendation on what brand of oil aside from oem. And how many miles should i change transfer case and rear diff oil?
on mr you should change your oil earlier than the dealership says, ive seen videos about that and when you see the oil its dark as hell, they say to change it at 40.000 but you should do it half way more or less,this video should help you to show how bade it will come out at 40.000
i strongley advise to get that filter and oil pan, im getting one next month. actually you dont have to just use the dealers oil, there are good oils that have the especification for that kind of tranny, at the moment i dont remember which ones especificley but i think amsoil has it, and amsoil has the reputation of being the leader in lubricantes for years.
Thanks everyone for the reply. Its a gsr. I think i will go with oem because i dont drag/track.So, JTEVO are you saying change tcase and rear diff oil at 30k miles also?
Yes, both of those are fine, though I have had better luck with the Redline.
To the OP, it doesn't matter if you don't track or drag your car, the Redline cocktail improves the shifting of the transmission ov the stock Diaquen.
I would highly recommend changing the rear diff and T Case as well, but for those two you do use the Diaqueen oem fluid.
+1 on the Redline Cocktail for the GSR
You can find as a package deal here:
http://www.maperformance.com/redline...l#.UMGgf5PjkaA
