Is this what it cost to get approx 350hp?
This is my first post here and i'm looking to get some advice. New to the EVO but not modding cars. Just sold my slightly modded Lambo and have done a Porsche GT3RS along with many old muscle cars. I am looking for approx 350hp to the wheels. I'm an old guy so i dont want loud exhaust ect.. I contacted 2 places to get quotes. I will leave the names blank. Here is the list of parts. As you can see one is a company that only sells the parts the other is a shop that sells and installs
This was the shop total of apprx 7k
3.5” Evo X Intercooler (We can anodize black to give it that “under the radar” look)
Upper intercooler pipe (I recommend wrinkle black coating for the stealth look)
Lower intercooler pipe (More for aesthetics than performance. Basically completes the kit. )
ETS Intake (again wrinkle black if you want to keep it stealth/OEM looking)
Recirculated Downpipe
ETS Test pipe (we can build them with a high flow catalytic converter or a resonator if you’d like.)
ETS Quiet cat-back exhaust
GrimmSpeed EBC or a Manual Boost Controller
Some Sort of tuning software which we recommend getting a COBB Access Port but FFTEC can advise what they look to tune with.
This should be everything you need to get you to your goal. We have numerous cars making over 350WHP on this setup and should be easily attainable
This was 3100.00
Thoughts?
Vince
ETS EVOLUTION X INTERCOOLER AND PIPE KIT. (PLEASE SPECIFY COUPLER
COLOR, ETS STENCIL, AND PIPING COLOR WHEN ORDERING)
943.95 943.95T
INSTALLATION OF FMIC AND INTERCOOLER PIPING 2.5 125.00 312.50
AEM COLD AIR INTAKE,CLEAR, EVOLUTION MR/GSR (2008-2010) 350.00 350.00T
SYNAPSE SYNCRONIC MINI DIVERTER VALVE EVO/3000GT/GTR. (REPLACES
16505A)
269.99 269.99T
INSTALLATION OF AEM INTAKE 0.75 125.00 93.75
ETS V2 QUIET CAT BACK EXHAUST, TWIN TIPS 950.00 950.00T
ETS 02 ELIMINITOR DOWNPIPE WITH RECIRCULATED WASTEGATE DUMP 495.00 495.00T
FFTEC TEST PIPE, EVOLUTION X 129.99 129.99T
INSTALLATION OF EVO X DOWNPIPE WITH INTEGRATED 02 HOUSING 550.00 550.00T
INSTALLATION OF TEST PIPE AND EXHAUST SYSTEM 1.25 125.00 156.25
FFTEC BOOST SOLENOID ASSEMBLY 85.20
BOOST SOLENOID INSTALL, EVOLUTION X 75.00 75.00
Genuine OEM Mitsubishi fuel pump relay for Evolution X 20.58 20.58T
INSTALLATION OF FUEL PUMP RELAY 0.1 125.00 12.50
BLAQOPS FUEL PUMP INSTALL KIT FOR EVO X
-INCLUDES WALBRO 255
250.00 250.00T
BLAQOPS FUEL PUMP AND LINE KIT INSTALL, EVOLUTION X 100.00 100.00COLOR, ETS STENCIL, AND PIPING COLOR WHEN ORDERING)
943.95 943.95T
16505A)
269.99 269.99T
250.00 250.00T
FUEL INJECTOR CLINIC Mitsubishi Evo X Injector Set: 4x900cc Saturated / High
Impedance Ball & Seat Injectors. Requires pigtails PGT USC4 or P & Play adaptors
PADPUtoD4.
409.00 409.00T
INJECTORS REMOVAL AND INSTALLATION, EVOLUTION X 65.00 65.00
NGK ILKR8E6 SPARK PLUG 4 14.775 59.10T
INSTALLATION OF SPARK PLUGS 0.25 125.00 31.25
LANCER EVOLUTION X PRE-DYNO INSPECTION
-VERIFY AFTERMARKET MODIFICATIONS INSTALLED CORRECTLY (PER HOUR
CHARGE)
-BOOST LEAK TEST (DOES NOT INCLUDE REPAIR OF BOOST LEAKS)
-VERIFY VACUUM LINES INSTALLED CORRECTLY (DOES NOT INCLUDE REPAIR)
-SPARK PLUG INSPECTION. VERIFY PROPER HEAT RANGE AND GAP.
-INSPECT TURBO FOR SHAFT PLAY
-INSPECT INTAKE FOR DIRT AND OIL
-INSPECT MAF FOR DAMAGE
-INSPECT VEHICLE FOR RATTLES (DOWNPIPE AND TRANSFER CASE)
-INSTALLATION OF WIDEBAND 02 SENSOR FOR TUNING (ONLY ON TWIN
EXHAUST VEHICLES)
140.00 140.00T
ECU DYNO TUNING DSM AND EVOLUTION 8-10 2 250.00 500.00Impedance Ball & Seat Injectors. Requires pigtails PGT USC4 or P & Play adaptors
PADPUtoD4.
409.00 409.00T
CHARGE)
EXHAUST VEHICLES)
140.00 140.00T
This was 3100.00
Thoughts?
Vince
tried numerous times to read what you posted. Just couldnt bring myself to finish it. Maybe its bc I am getting old, but damn, that font is tough to read without paragraphs.
But since you had a gt3rs I will give this a shot.
It should not cost you 7k to get 350whp.
Downpipe, exhaust, test pipe (or HFC in NorCal), intake, LICP, (FMIC/UICP are nice but not necessary for 350whp), MBC, fuel pump, tune.
You do not need (or want) accessport, and do not need expense EMS. Have it tuned by a respected tuner, with a mbc, and crank up the boost.
Add misc. goodies on there for a few extra hp and cost (like guages to monitor etc).
edit --- just remembered this was cali, and you will be on 91 gas. slightly harder, not at all unattainable. 7k for 350whp is still on very high end.
gl with the mods and post some pics of evo and other toys
With your option # 2 @ 3100.00 dollars you should meet your goal depending on who tunes your car and what type of dyno they use.
My mod list:
Ets upper intercooler pipe
Grimmspeed 3 port
Magnaflow exhaust
High flow cat
Cobb so cal tuned with accessport
331 hp 330 + tq. On a mustang dyno
Numbers suppose to be about 8% higher on a dynojet.
Cost me about 1800.00 to make that amount of hp.
No intake needed unless you upgrade your turbo. That's what my tuner suggested.
My mod list:
Grimmspeed 3 port
Magnaflow exhaust
High flow cat
The 3100 option should easily get you the power you want. Its interesting they do not mention putting in bigger injectors and running e85. That alone will easily net you a big increase and along with a few bolt ons, upper and lower ic piping as well as a bigger core, a tune and a boost controller witb a full exhaust. 350 should be fairly easy.
Just out of curiosity what type of lambo? Gallardo? Murcielago? Or more rare like a diablo or countach.
Yea i was going to say 7k is expensive. You can get a cobb stage 3 kit for cheaper.
http://www.cobbtuning.com/Mitsubishi...p-p/652x3q.htm
350
Ya, being an old guy myself it was pretty hard to read. Not sure why it came out so small. The 7k seemed high to me also. This shop was even going to charge me for checking the work that they had done, ie, if there was a leak ect.. seems to me if you charge me to install it you should fix it if its not done right. i just picked up the 2014 Evo X. It will just be a mess around car..running around in the hills ect.
It was an 07 Gallardo. I was just getting tired of getting these exotics ( had a 360 Ferrari, 6.0 diablo, Ford GT and a few others) but just didnt drive them. I have a few old muscle cars now, ie, 70 Boss 302, z28 ect.. and a 88 M3, 86 16v 190 E Cosworth ect.. All fun cars but i wanted to get something i can beat on a bit without the worry of a 10k repair bill.
Vince
Vince
gotcha.
Vince-- Plan on running 91 or any access to E85? E85 will get you killer number on a safe tune, but if your looking for just something to beat around in then probably not worth the hassle.
If a shop is going to charge you to double check the work they already did, go somewhere else.
I know there a bunch of good shops up in the NW, just ask and the locals will send you in the right direction.
Do all the basic bolt ons, tune, and be done. get you to your numbers, and be right around that 3k mark depending on brand selection.
gl with it and happy modding
Our package 1 and package 2 along with a tune will get you where you need.
http://www.extremeturbosystems.com/Package-Deals/
Any questions, don't hesitate to ask.
Thanks!
Michael
Thanks!
Michael
Vince
Vince
Brilliant!!
350
---NOTES TO CUSTOMER---
THE ABOVE PARTS ARE GOOD TO ROUGHLY 290-300WHP ON OUR INHOUSE
MUSTANG DYNO. TO GET TO ROUGHLY 350 WHP IT WOULD REQUIRE AN
AFTERMARKET TURBO WHICH IS LISTED BELOW.
IF THE BELOW TURBO IS ADDED, THE PRE-DYNO INSPECTION AS WELL AS THE
DOWNPIPE INSTALLATION WOULD BE COURTESY INSTALLED.
0.00 0.00
EVO X GTX3076R BOLT ON TURBO KIT (INTERNALLY GATED) 2,988.59 2,988.59T
10% Discount -10.00% -298.86
TURBOCHARGER REMOVAL AND INSTALLATION, EVOLUTION X 605.00 605.00
AMSOIL 10W 40 SYNTHETIC PREMIUM MOTOR OIL, INCLUDES ZINC 5 11.99 59.95T
GENUINE MITSUBISHI OIL FILTER 8.95 8.95T
ZEREX Standard Antifreeze 16.00 16.00TTHE ABOVE PARTS ARE GOOD TO ROUGHLY 290-300WHP ON OUR INHOUSE
0.00 0.00
Just one turbo.
Vince
