Clutch slipping in cold weather??
Not sure if the if the freezing temps and a not quite warmed up car can equate to slipping clutch at low speeds under load. I've drivin manual cars for a long time and have never experienced this.
Car is modded making 350/340. Stock clutch? It has 12k miles and I don't abuse the car every day.
Remove the pill and see if that helps; with only 12k miles I wouldn't be surprised if that alone fixed your problem.
It's a little plastic pill and spring inside the clutch slave cylinder which is located underneath the stock airbox. Remove the banjo bolt and bleed nipple, poke it out with a small allen wrench, reinstall banjo bolt and nipple, then bleed the clutch system to remove any air bubbles.
Is it possible for something like this to malfunction and make the clutch slip? It slips as soon as I get into boost. Especially in 4th/5th.
Also, I have the dealer doing the slave cylinder recall soon, will they void anything because of this?
