Evo X RS vin
Evo X RS vin
can someone help me plz - I want to check some parts which were only on Evo X RS, but to do that I need EvoX RS VIN, and I can`t get them as they didnt sell in Europe.
would apreciate if someone could give me one
thanks a lot!
thanks a lot!
Actually, the RS was available in Europe, albeit as a special order as opposed to off a lot. And there is nothing in or on an RS that isn't in or on a GSR or MR. The RS is a stripped-down model intended for building a race-car.
Anyway, here's the answer to your question: JA3AW86V69UXXXXXX
thanks a lot for your help!
the reason why I ask - I know that some people install rear diff from 9RS on evo X and I wanted to check how it can be done
thanks for help!
thanks for help!
Ah, if that's the question, then you want to ask Rob Martai (RobEvo on this site), as he's done it. The gearing matches, so it's pretty straight-forward. The only real question (in my mind) is whether you re-use the sub-frame from the X or get the sub-frame from the donor car; that's what you need to ask about. The axles must come from the donor, because the diffs are quite different (as it were).
The other question is whether you're going to flip the plates in the Evo 9 diff for more locking or replace it with something like a Cusco MZ. That's the $2000 question.
Blizzard25
Sep 7, 2014 04:27 PM
