Bypass emission test?
I am looking for an OBDII simulator and/or emulator and I am having absolutely zero luck!
Does anyone now where I can find one? I need it for purposes of emissions hehehe
if you have a test pipe or HFC, you will need a o2 fouler to trick the ECU thinking cat is on the car or else CEL will flash and emission test would fail.
I dont think you can just set it to ready and pass emission it has to complete test on its own
hmmm.... well that complicates things... interested from anyone that has EGR, evap, and cat removed and how they are dealing with this? Anyone with hands on info on whether or not you can get away with just setting the readiness without needing the system and connections installed?
OP Sorry if I have jacked you thread in anyway. If so I will kindly create my own. This just has me rather intrigued as I will be dealing with this in a year form now
here you go
http://www.ebay.com/itm/ECUsim-5100-Professional-OBD-II-ECU-Simulator-601501-/171139325429?pt=Motors_Automotive_Tools&hash=item27d8b2ddf5&vxp=mtrgood luck
theres quite a few on ebay.
I found this simulator while searching around, but I haven't found anyone who has tried it yet.
http://www.immensehardware.com/elect...reme-obd2.html
If you have a cobb access port you can have everything set to force ready. I did this on my subaru when I had to pass a sniffer test because I kept getting a missfire ghost code because of having a lightweight flywheel and pulleys on the car.
