Service Engine Light came on after some pulls.
I installed my catback exhaust ( Invidia Q300) and ETS HFC about 4 days ago and I've been pullin it a lot these past couple of days maybe 7 times. and today just randomly driving my service engine soon light came out and it was 46 degrees outside. Is this normal cus i replaced the cat? or should i be worried?? I'm not tuned yet, i scheduled it in a month. So should i keep driving or no??
Switch it back to stock or get a tune asap. Like Omar Ramos said you need to get a tune. The HFC is allowing more air to move than the ECU can adjust. Your fuel and air ratio is out of whack most likely. If you have it I would hook up the tactrix cable and ECU flash and read the service code and see what it says.
^^^ what no limits and Iowa said. I would just keep driving it and check the code to make sure it's nothing serious. If u installed an intake I would be more concerned but for a hfc and catback I wouldn't worry about it.
Changing to the ETS HFC is changing the test pipe correct? I thought you have to get a tune if you change the test pipe (to a wider one, HFC, straight pipe, etc)
As to the code coming during a "pull": many codes are only triggered at high load and/or flow rates. That part of the story is not surprising at all. If, for example, you go WOT on the first cold day, you'll often throw a minor (and temporary) code as the long-term fuel trims don't move quickly enough. If you stop driving when this happens, the LTFTs won't adjust and you won't know that it wasn't a big deal.
some people dd these, if something horrible is wrong with his car and he keeps driving it he will be paying loads of money, let someone who gives zero ****s about their car drive it with codes popping up, so why take that 1 chance if it being something actually serious over its probably nothing?
just saying bro im almost positive most people rather be on the safe side
I love how people keep saying oh no worries keep driving. Funny thing is any PROFESSIONAL TUNER who has been doing vehicle work for years is going to tell you to tune the car no matter what the part is. Why would you risk a car worth thousands of dollars for a part that cost a few hundred . I don't get the mindset behind this. People are always looking for a cheap way out to not get a tune. All cars are different even if you have the same model year etc. They all act different. Perfect example is when I changed my intercooler it threw my AFR off by 4.0 which is a ton. What works on one persons car does not mean it will work on another and be ok. Tuning not only ensures performance but it ensures a proper safety measure to make sure that part is working in unity with your car. PERIOD
Well, let's see what the exhaust will do. The increased exhaust flow can raise the boost slightly. If you're running stock, then there is plenty of margin for this. The ECM sees this flow and compensates fuel appropriately. It will just give you the feel of increased performance that will be credited to the exhaust. The HFC will flow more, giving the secondary o2 above average readings, making it think the catalyst is below threshold....which will throw a code. That's really all there is to it.
