P0068 - Stock 2011 MR with Panel Filter Drop In
Old Dec 28, 2013 | 08:39 AM
Roen's Avatar
Should I be worried?
It was 34*F outside last night when I decided to have some fun and took it to redline with 2nd gear pulls and 4th gear pulls at different times of the night. As I was getting home, the CEL went on. Car was idling around 2200.
I took out my OBDII scanner and read the P0068 code. I started doing some research on the forum. It seems like this code pops on during cold weather and WOT pulls, but seems to go away on the next restart of the car. However, sometimes it creeps back.
Also, the majority of cases happens to cars that are 1. untuned and 2. modded.
Seeing as how I have pretty much a stock car, should I be worried or should I delete the codes and just drive it as usual?
Old Dec 28, 2013 | 09:06 AM
deprydation's Avatar
I think you answered your own question.
I'd delete the code and move on with life.
Old Dec 28, 2013 | 08:26 PM
ikt's Avatar
ikt
Run without a tune at your own risk
Old Dec 28, 2013 | 08:45 PM
Roen's Avatar
I only have a panel filter.
I need a tune for this?
Old Dec 28, 2013 | 10:52 PM
Kendogg's Avatar
I haven't thrown that code in a stock or modded Evo, in the cold or the heat. I would just clear it. If it happens again, then just put the stock filter back in.
Old Dec 29, 2013 | 03:09 AM
Johnr352's Avatar
You mean, everything is stock except you've replaced the air filter with a K&N or something? That wouldn't in itself require a tune. Clear the code and see if it returns, if so, try swapping back the oem filter, as someone advised.
Old Jan 2, 2014 | 01:38 PM
Roen's Avatar
Code cleared, hasn't come back yet.
Old Jan 26, 2014 | 11:04 PM
Roen's Avatar
Funny how after this thread came up, I received the recall letter for precisely this issue.
Old Jan 27, 2014 | 02:09 AM
ChUt26's Avatar
Big brother is watching
Old Jan 27, 2014 | 06:51 AM
OffsetZ33's Avatar
Is that reflash for this issue? I thought I read it was for something else
Old Feb 4, 2014 | 10:06 AM
Roen's Avatar
Yup, torque tables.
Si1ver
Jun 12, 2022 04:29 PM
Midwestmaniac
Mar 17, 2017 09:22 AM
tripletaco
Lancer Engine Tech
Nov 2, 2015 06:53 AM
1711902090
May 27, 2013 09:15 AM
slvevo8
23
Dec 23, 2009 08:34 PM
Quick Reply: P0068 - Stock 2011 MR with Panel Filter Drop In
