How many gauges can run off the cigg lighter fuse?
Is it possible to run 4 gauges off of a single fuse tap (making a small distribution block using the cigg lighter fuse). If not are there any other fuses to tap into that only are only powered when the car is on?
You need to see what the amperage is that the 4 gauges are going to pull. If they exceed the fuse rating then it will blow. So to answer your questions, it depends on what the draw will be and the rating of the wires used. If you pull to much you blow the fuse or melt the wiring.
I'd imagine your tapping into the ground next to the dead pedal. Connect one probe of the multimeter to the negative of the gauge's wires and the other probe to the ground. Basically you're using the multimeter to complete the circuit while displaying actual power being drawn.
I'm no expert, just sharing what I did. Right now I have three gauges and my AIM Sport Solo DL on that fuse.
If you intend to use your accessory plug I would say no. I had a O2 and Boost gauge on mine and I was charging my cell phone and it went. After that I ran a cable from the battery to a fuse box I made to run my gauges. Buried the box below the navi.
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
