Check engine notification during acceleration.
So my problem is that when I accelerate in 1st and 2nd gear and sometimes in 3rd or 4th if I pass someone, I get a Check Engine notification on the display panel (where it shows the mileage of the car) and the brake light comes on. The notification and brake light turn off after a few seconds. This happens when I give it a little extra gas, maybe 50% throttle. I do not notice any hesitation and the yellow check engine light does not come on/is not on. This just started about a week or so ago. My mods are listed in my sig. Any help would be greatly appreciated.
Check your brake fluid and pads. If your pads are worn down the brake fluid level will drop and any sudden movements will cause it to think it's low on fluid. Is it a circle with an exclamation mark that pops up in the display?
the check engine flash is an aftermarket software modification called "tephra mod"
because a programmer named "tephra" wrote it
your car has a tune on it that is set to flash that light if your car is knocking under full acceleration. It's a safety feature, but it is alarming if you don't know what it is or why it's doing it.
FS[Northeast]: FS: Escort Passport 8500 x50 (Red Display)
nystc23
For Sale - Miscellaneous Automotive
May 8, 2015 12:15 PM
johnjonfenomeno
Aug 6, 2003 01:04 PM
