RPM issue
RPM issue
I've been having a weird issue with the RPM's on my X that I was hoping I could get some tips on troubleshooting it.
Issue 1) When I am driving, and I come up to a stop sign, as I press the clutch and put the car in neutral my RPM's will sometimes drop to 800-1000, but then surge from there to about 1500 RPMs. It surges about 2-3 times then the idle will go back to normal.
Issue 2) When I am in stop-and-go traffic my RPM's will go up to about 1700 RPM's when I push in the clutch without even hitting the gas.
I don't know if it is a vacuum leak, or maybe an issue with my TPS. Outside of those two issues there are no other problems with my X. Could those issues be linked to something wrong with my clutch or related parts?
No, that is not normal. And for me, the cause was the tune. After I got retuned by a different tuner, I haven't had the idle bounce since.
Mine never did it stock. It would drop the idle some, but then would go back to normal idle. It never bounced high and low like I posted above. Not until after I was tuned. It was almost like the car was trying to find idle but couldn't. So it would bounce high or low until it finally found it.
I wish a new what the fix was, other than a new tune. My original tuner locked my tune and wouldn't unlock it so I had no way to look at the tune and compare it to my new one to see what the difference is.
EVO8LTW
31
Nov 5, 2010 05:21 PM
