Sponsored by:
Sponsored by: CARiD
welding o2 bung on test pipe is less accurate?
Old Jun 30, 2014 | 04:35 PM
ThaoDao's Avatar
I have an ETS downpipe, but when I ordered it I forgot to add the wideband bung on. Now I have to remove the downpipe from my car and get the bung weld on, but that's a lot of works. I'm thinking welding o2 bung on my test pipe instead, but a friend of my told me that it reads less accurate on the test pipe. Is that true? Can I just drill a hole on my downpipe without removing it?
Old Jun 30, 2014 | 05:53 PM
Kartyman550's Avatar
Ah, I wouldn't worry about it. I mean the best reading is on your down pipe on a 15 degree angle as close to your turbo as safe so... If you have a safe tune you;ll be alright
Old Jul 1, 2014 | 05:51 AM
the 10th 1dr's Avatar
Down pipe afrs are more accurate than test pipe afr readings. By how much, i am not sure.
Old Jul 1, 2014 | 05:22 PM
sgtr275's Avatar
I would be curious to know where you got that information from.
But to answer ThaoDao, it shouldn't make any difference.
Old Jul 4, 2014 | 01:51 PM
errdisab1e's Avatar
I'm not sure but another variable could also be the wideband sensor + afr gauge brand. I have the Prosport Halo AFR that came with a Bosch 4.9 o2 sensor. It reads -1 lower than what my tuner was reading. (Ex: on 3rd gear WOT, gauge shows 11.xx and tuner's screen was 12.xx)
Tuner had his sensor on the left exhaust pipe. My wideband is on my DP. I have a MXP short DP
If your concern is geared towards monitoring vs tuning off of your gauge, I would note what your AFR readings are and monitor for changes
Old Jul 6, 2014 | 12:43 PM
ravenjam's Avatar
I welded a second bung into my test pipe for my wide band. I compared my readings to that of my tuner's reading from the tail pipe, the readings were a spot on.
Old Jul 7, 2014 | 12:20 PM
bluescoobywagon's Avatar
Provided there are no leaks before the test pipe, the readings will be accurate, but they may be slightly delayed. On a map with fairly consistent fueling, it wouldn't have much effect.
Old Jul 7, 2014 | 03:32 PM
ikt's Avatar
ikt
AEM makes a kit where you can just tap in and use a band.
evostang
Evo X How Tos / Installations
33
May 16, 2019 04:22 PM
Bman513
Aug 10, 2016 02:24 PM
Blue91lx
Sep 29, 2011 01:02 AM
Hendrixmx
Aug 16, 2010 02:43 PM
Gibby860
11
Sep 16, 2009 06:15 PM
