Handling Performance or Tire Life?!?
#31
#34
I took them back to discount tire and had them put on some RA-11's and those are fantastic tires. Very very close to the feel of the stock Advans but not as expensive.
Sorry, but the PSS should be sued for putting 'super sport' in their name. That tire belongs on Mini vans or something else other than a high handling car.
#36
The sidewall rollover is completely unacceptable unless you never drive the car hard.
I didn't spend 200 bucks to get rid of them for no reason.
PSS = Tire for a minivan not a an EVO
#37
Sorry but you really need to run in a car with the stock tire, or an aggressive tire with a rigid sidewall like the stock tire has, or the RA-11's, and throw it through a turn, then try with the PSS.
What's an RA-11?
Bstone RE-11? Toyo RA-1?
#38
These are what I am running and they are as close to Advan's as you can get imo.
http://www.tirerack.com/tires/tires....=Potenza+RE-11
". The Potenza RE-11 features an asymmetric tread pattern that combines massive outboard independent shoulder blocks interlocked with a notched circumferential intermediate rib that provides the lateral stiffness needed to enhance steering response and increase dry cornering traction. "
Fantastic tire, endless grip. My stockers wore out after around 12500 miles, I have about 10k on these and there is still decent tread left.
I won't be getting a different tire going forward after my horrible experience with the PSS. My wife's words still ring in my ears "Did you break the car?" As I threw it through a corner we know and the car slingshot back over the sidewall and made it feel completely out of control.
Tires went back that week as soon as I could make an appointment lol.
Anyone that doesn't believe me? Take your car out before the PSS is installed. Going about 30-40mph on an open road do a hard lane change then back again. Now put the PSS and do the same thing. Welcome to hating the PSS.
#40
Sorry I had one wrong letter.
What was your alignment on the PSS? Probably needed a lot more camber to combat the sidewall flex. That tire seems to need two completely different alignments for performance driving and DD.
#41
I run the RE-71R now. The Bridgestone tire after the RE-11A, which is the tire after the RE-11.
I'm really not sure how any amount of alignment manipulation could make those tires feel anything other than dangerous. Literally when hard turning or aggressively changing lanes the car would slingshot back over itself after the sidewall folded then sprung back. Extremely dangerous feeling to have all that weight being tossed around without control.
PSS would be great for a road trip but I'd never, regardless of alignment setup, run them as anything more than straight line boring driving.
#42
I had zero toe all the way around, which felt and feels great with current tires. Not sure what camber if any was set.
#43
On a stock size tire (245/40) there will be a little more sidewall flex on a PSS vs another performance tire. My front camber was -3.6 on those tires at 36 psi hot. That setup and camber gives grip levels on par with the Rs-3 and AD08. Also, due to the two different compounds used on the PSS, you'll get 30k aggressive DD miles out of a PSS vs 10-15 for the rs-3 and ad08. Softer sidewalls have the benefit of a much more plush ride on the street and much better stability under braking.
Just for comparison, i now run AD08-R's in 295/30, which is a tiny ****ing sidewall. The AD08's are notorious for a stiff sidewall and i'm having to run -2.9 to -3 camber up front in order to get even tire temperatures. What i'm trying to say is, .6 degrees of additional camber isn't the biggest deal in the world, but its certainly noticeable if you're stuck on stock alignment bolts.
I give a +1 to everyone reccomending 0 toe at all 4 corners. You'll get another 1-2 mpg with zero toe and the car will be much more balanced in the twisties. Also, rear rotation is hard to induce with confidence if you have any toe in.
If i were you, i wouldn't run factory sidewall heights. Get a 245/35. If you're on springs and you flip the camber bolt, you should be able to squeeze ~2 deg of camber up front.
Another note, don't mistake softer sidewalls for decreased grip. A stiff sidewall might provide more "response" but ultimate grip is a totally different thing unrelated to the rate at which you can change direction. Smooth out your steering inputs, you'll be faster i promise
#44
Meh all good, if you can find a way to make the PSS work then more power to you. I can't fathom how some camber would make the tire feel any less safe than it did for me doing very minor maneuvers such as sweeping turns into a transition to a new curve and reasonably spirited lane changes and the like.
Without any specific settings the new tires I got just 'worked' and felt like the car did stock with the Advans.
Roll them if you love them, but I never will again.
-Peace!
-Peace!
#45
-Peace!
-Peace!
Just wanted to put that out there.
