loud exaust without deleting cat
Old Jul 14, 2015, 12:31 PM
evolution13's Avatar
Hey how are you, i have a 2015 evolution gsr and im looking for the loudest possible set up for my exaust without deleting the cat and without a tune. Does anyone have any recommendations.
Thank you
Old Jul 14, 2015, 12:42 PM
MisterRegato's Avatar
I'm fairly certain if you want a full exhaust you'll need to get a tune. Might find a cat back that doesn't need one? My cobb exhaust wouldn't work for you, not loud enough.
Old Jul 14, 2015, 12:56 PM
TxFAkuma's Avatar
What's better ETS V2 or ultimate racing exhaust? For loudness that is.. I don't think you need a tune for the ETS V2 or Extreme Exhaust. . Do you?
Old Jul 14, 2015, 12:59 PM
e_kobz's Avatar
ETS V2 Extreme cat back
Old Jul 14, 2015, 01:00 PM
shekaar's Avatar
Looking for single or dual exit? There are a variety of options that are loud, ETS has some loud ones. I just put the Tomei Expreme single on mine (though I have no cat), and it is much louder than my Invidia Q300 I had.
Old Jul 14, 2015, 01:43 PM
hoobastnk90's Avatar
or.... you could just unbold the muffler on the exhaust and that should be pretty damn loud! And for the extra rice effect just unbold it from the cat!
Old Jul 14, 2015, 01:45 PM
e_kobz's Avatar
Old Jul 14, 2015, 02:15 PM
I want to do a ets exaust but neither of them come with a cat and im assuming when you delete a cat you need a tune. I currently have the corsa catback exaust which sounds pretty nice under acceleration but it is not loud enough for me. So im looking for the loudest exaust but i would need to keep the cat due to needing a tune? Im still new to the car so im still learning.
Old Jul 14, 2015, 02:34 PM
Yes you would need to keep the cat otherwise a tune would most likely be needed. Just get a single exit exhaust it most likely will be much louder and make sure it has no resonators in it as well.
Old Jul 14, 2015, 02:56 PM
e_kobz's Avatar
I'm not understanding the issue, keep the cat that's already on your car and get a ETS exhaust.....
Old Jul 14, 2015, 04:13 PM
If i do buy the ets extream what would be the easiest way to make it fit with a cat cause they dont come with one initially
Old Jul 14, 2015, 05:04 PM
the 10th 1dr's Avatar
Just get the adapter plate. It will fit
Old Jul 14, 2015, 05:12 PM
Broham's Avatar
Get a test pipe resonated to look like a cat and the tuner can make it pass since no sniff test on 2015. too much hp lose with cat.
for noise no muffler is loudest way. The Loudest is when exhaust gas just exits straight up. Most manufacturers will use same gauge steel. THe biggest factor is mufflers and resonators. Take them out and ultra loud
Old Jul 14, 2015, 05:33 PM
Viegasjuice's Avatar
There is a difference between loud and good sounding. ETS has nice exhaust. I own a ets single exit that is straight piped 3" that has a 4" tip. It sounds beautiful and is very loud. Now I run it catless with the ETS test pipe. It pretty much sounds like a race car and does not sound ricey at all. My dads evo x has the ETS v2 extreme dual exit with the stock cat. Sounds VERY nice and it is loud also. Videos dont replicate the sound well at all. Both exuasts are very light aswell.
Old Jul 14, 2015, 06:09 PM
Where can i buy a adapter plate for the v2 extream
Quick Reply: loud exaust without deleting cat
