Charging systrem malfunction after clutch swap
Hello, This past week I swapped the clutch on my evo, and ever since the charging system service required light has been on. I've checked the wiring and it seems fine, no fuse able links have been blown, however when the car is running the voltage off the postivie is only at 12.2, so it almost seems the alternator went bad. When measuring the voltage off the alternator it reads around 2.4 with teh car on and 10 with it off, is this a sign of a bad alternator? Or anything else it could be?
Welp figured it out, somehow the positive wire going from the alt to the fuse block was loosened so it was just barely making a connection but not enough to charge the battery, tightened it up and all fixed
detroit pistins
13
Dec 19, 2013 10:43 PM
jxs1984
20
Nov 2, 2010 05:46 AM
Volkmann
Jul 14, 2003 10:24 AM
29
Mar 10, 2002 12:17 AM
