Clutch Engagement Point gets lower and lower
I have the AMS master cylinder upgrade. When I first start driving the car everything is normal. After about 10 mins, the clutch engagement point starts to slowly get lower and lower up to the point to where it no longer engages and I have to shift without using the clutch. My reservoir is full and I dont see any leaks by the pedal. Havent had a chance to bleed it yet, but I dont think that's going to fix the problem. Any suggestions? Also Im running the quarter master 8 leg.
First try bleeding the system, the most common leak location would be from the foot well area if it were leaking.
You may be thinking of the Ams ring that they came out with for a bit, however I am talking about the complete assembly that they have. I have checked for leaks and can not find any. Next on the list is to bleed the system but as I said, the engagement point is nice and stable for about 10 mins of city driving. Then it slowly starts to lower itself until it's on the floor. After the car is parked for a few hours, the process repeats itself.
Thankfully it's not my daily and is sitting at the house. It works fine for a while, then the engagement point slowly starts to get lower and lower as the amount of "free play" in the pedal increases. I have to keep pushing the clutch farther and farther down before it will engage.
Fluid is good, and already have the braided lines. I"m thinking I may just sit in the car and see if I can replicate the problem without actually driving it down the road.
But something weird is going on and all signs point to a leak or air in the system. I would think air in the system would behave more consistently though and not depend on how long the car's been driven.
By that same logic though, I don't know how a leak would "fix itself" between drives.
How are you able to get into first gear from a stop when it's acting this way?
disengage* btw. Pushing the clutch pedal down disengages the clutch. Lifting up engages the clutch.
Could possibly be a bad slave cylinder. I had a similar issue happen to me. It was a Honda. May not be the same car but your issue resemble what I was going through turned out to be the slave cylinder that was the culprit. Just throwing it out there.
kf6ytc
May 22, 2006 11:28 AM
elhalisf
42
May 18, 2006 11:40 AM
smackdaddy
Mar 10, 2004 08:34 PM
