Tarmac, gravel, snow light flashing
Hello all,
Awhile back my tarmac light would flash on a very inconsistent basis. Throughout the last few months it has become very frequent. I've taken it to the dealership many times and they have said they've cleared a code that indicates a slip in the drive train. They have cleared this code 3 times now and has not fixed the problem. They have insisted nothing is wrong with the ACD pump.
My question is had anyone heard of a code indicating a slip in the drivetrain.? Can I even trust the dealer that they are reading this code correctly? Avoiding a costly ACD pump replacement? Anyone else have the flashy light problem and what fixed it? Thanks!!!!
Sounds like the timing chain perhaps? How does a dealership say there is a slip in the drivetrain and send you on your way without any more information or how to fix it?
Past that I would request they diagnose your transfer case as well and look for leaks.
Do you have an MR or GSR?
This happened to me before. Go to your trunk, look on the right side of your trunk for a little door. Pop that open and youll see the ACD fluid, check to see if its at the correct level. Mine was not anywhere near sufficient so my little tarmac sign was flashing occasionally. Went to the dealer and they bled the acd pump/fluid and refilled the fluid - problem was fixed.
The dealer told me if I didn't fix this problem, it would have screwed my AWD system. cost me $110 in total I think.
Another reason I read online is that when you drive the car overly hard, it will flash as well to let you know that youre driving it a bit hard. But that has never happened to me after I bled the fluid and I drive my car hard sometimes... GL hope you get it fixed soon
before you go adding fluid all willie nilly that level changes as you drive and even after you first park and turn off the car it will change. So be careful when you decide to add fluid.
Had the same problem after my clutch install on a 2014 GSR. Just needed to put a tiny bit more fluid in my ACD reservoir. Problem solved. If your fluids are at the line or above, then you have a pump about to die on you. Demand it to be replaced if that is case. It is a fairly common issue.
This.
So how many of you are actually having to replace the pump. My light has just started blinking at me. Fluid looks fine. I don't drive it hard or track it. I have a Cobb tune and ETS intake and v2 exhaust. I see all kinds of threads saying the pump is terrible and it's about to die if it's blinking. I have a 2013 GSR with 22k miles. Is it really that ****ty and won't be under warranty?
But it's safe to assume that if the light is blinking, my fluids are fine then the pump is going and will not be replaced by Mitsubishi. My Cobb ap and slight mods would not be throwing a false code.
