K&N typhoon
K&N typhoon
Hey guys I'm new here (obviously) I've done a search for cold air intake systems and the results are all over the place. I'm looking at the K&N system for my 2015 GSR. The reason I'm posting is this: K&N only has it fitting through model year 2014. When I contacted them they said they have not tried to fit it on a 2015 so they don't know if it will fit. Have any of you fine people put one on a 2015? If so were there any mods that needed to be done to fit? Thanks
it will fit a 2015 as its no different than the other years. I bought one for my FE, and it fit alright, but I just wasn't crazy about the quality, as I'm a bit ****, so I returned it two days later and just bought a k&n panel filter
I don't think you guys should be running intakes on your cars without tunes.
I also think that if you were putting intakes on there as a first mod, you have done little to no research on your car and are going to get into bad territory really quickly. I know it's exciting to get a new car, but every car and platform is different.
This is a turbo car, changing the rate or amount of air into the engine should be tuned for. Drop in panel filter - ok - but I would recommend a Cosworth over the K&N because you don't have to oil the Cosworth. If you accidentally over-oil the filter and it fouls up your MAF then that's no bueno.
Napalm, I respect your opinion. However if you read my post I never said that the intake was the first or only mod that I was doing. Nor did I ever say that I would be running an intake without a tune. I did say I was looking at the K&N not that I was set on it. It was merely a question of fitment since K&N couldn't tell me if it would fit.
I stand corrected, and apologies in that case. We get a lot of people that come in here from different cars and throw an intake on first thing lol. You accidentally came across as such a newbie so I was suggesting based on that. No worries, glad you know what you're doing and enjoy the car
I really liked the Cosworth drop-in and ran it on my car stock. Made a big difference even without a tune. Cheap no hassle change and good gains as well.
Have a super day
Back on topic, the reason intakes need to be tuned, is because most have a larger diameter tube, which fools the mass airflow sensor and you get extra air that wasn't accounted for, you run lean and bad things happen. When an intake such as k&n uses the entire mass airflow housing, all calibrations remain in tact. You do get more intake noise due to the lack of airbox to muffle it, which makes you think you're going faster, but that's about it. I'm not defending anything, because if you read my post, I did say that the quality wasn't very good in my opinion and I returned it.
I would definitely look else where. ETS, AMS, STM etc make awesome products. I personally have used all ETS on my 9 and now my X. They make great products and are very helpful and easy to deal with. I had a buddy with the K&N intake and he switched it almost immediately.
The K&N intake is a great intake and perfectly safe to run without being tuned.
I wouldn't run ANY intake without a tune, I don't care what the company says so I stand by my statement. I don't believe in running turbo cars with aftermarket intakes without supporting tunes. Drop in filter? Ok. Outside of that I don't think it is a good idea, and most don't. I've done plenty of research to come to that conclusion thanks, and will repeat it over and over going forward as well.
Have a super day
Have a super day
jtanner_
18
Sep 12, 2013 08:50 AM
the_evodude
11
Feb 19, 2013 06:36 PM
Sol-Good
Jul 12, 2011 05:30 PM
