Where does this vac line go to? (PICS)
![](http://s31.postimg.org/79k1s4p2f/20160610_175912.jpg)
2008 Evo x Cobb Stage 2 tune
AMS tbe
AMS intake
Where is this vac line supposed to connect to? It's coming form the upper boost solenoid and it doesn't seem to connect anywhere. Also the boost pill is supposed to be removed right?
I'm also getting code P1320 Ignition timing retard insufficient. Does that have anything to do with it? Should I go to the dealer and get it reflashed? Should I replace the thermostat, since that may be a possible cause?
Follow the lines.... does one lead to the intake? Does the intake have the bungs? What map are you running (verify on the cobb)?
No need to take it to the dealer for a reflash. Run a search. I guess it was a common issue on early X's. The cobb should be able to take care of it though.
There is no nipple on the AMS intake for this vac line to connect to. . Tune is a Cobb stage 2 +SF (note: boost pill removed)I also check the line, the boost pill has been removed
woodc
14
Jun 2, 2005 05:38 AM
Evil EV0
Apr 5, 2005 06:14 PM
avengerhed
Sep 27, 2004 02:38 PM
PHiSH
14
Aug 26, 2004 03:09 PM
ASTROEVO
Feb 3, 2004 01:22 AM
