Need help on exhaust bolt length
Hi guys,
So before I install my new magnaflow exhaust to my stock cat. I know the bolts size are M12-1.25, but I was wondering if 25MM is long enough? If I remember correctly are the nuts welded behind the cat?
Hopefully I get an answer. Thanks everyone
I'm not sure the length, I want to THINK I used a 25mm and it was fine. You can always go to a 30-40 to be safe. I personally replaced the hardware with G8/10 Stainless to make it that easier when needing to work underneath the car. You wouldn't believe how many times you'd need to remove an exhaust piece to do something.
CantStopSpinin
15
Feb 11, 2009 08:19 PM
ruzs
Sep 23, 2004 06:23 AM
