Clutch master cyclinder full upgrade or not?
I have an aftermarket clutch on my EVO X but the clutch master cylinder is stock which is causing reverse to kind of grind because the gear is still circulating when I engage the clutch so I have to throw it in a gear then in reverse to avoid that. The clutch master cylinder is fine its brand new because there was a recall on it and it got replaced by the Mitsubishi dealer so my question is do I have to upgrade the whole clutch master cylinder and kit or can I just get the kit? Or can I just get the metal wires since the stock ones for the car are rubber and not strong enough because of the aftermarket clutch?
BMS Evo
54
Oct 16, 2013 05:16 AM
raiceboi697
Aug 16, 2010 08:47 AM
